Manchester area Tach and OBC fixed for £100?
E30325imanc
Post Sat Dec 10, 2011 9:25 pm
I have a non-working tach that is in all honesty getting me a bit depressed. I've trawled through the search articles on here to no avail. I basically need it working and have taken it to a couple of auto-electricians, who were non BMW and didn't really have a clue.
Would anyone be able to sort it for me? I can certainly provide some background into the wiring history - it did work at one time!
If someone could sort this pretty easily and fit an OBC for me (I've installed most of the wiring) then I'm happy to pay £100.
Not a bad little incentive for Christmas surely! Oh and you'd be doing me a mucho favour, because I can then start getting my interior sorted.
Feel free PM me for more details if you can help. I am in the Manchester/Macclesfield area
leeparkes
Post Mon Dec 12, 2011 12:04 am
Does everything else work on the cluster?
E30325imanc
Post Mon Dec 12, 2011 1:20 am
Hi lee. Yes, just that and the econometer
mrLEE30
Post Mon Dec 12, 2011 3:52 am
Econometer - does it just swing side to side or not move at all?
E30325imanc
Post Mon Dec 12, 2011 9:24 am
A few days ago the started to flick. But dead again now
Rtaylor2208
Post Mon Dec 12, 2011 10:56 am
Check Fuse 11 or 12, can't remeber exactly which one. I had the same problem and was down to butcherd wiring for the stereo. The speedo \ mpg guage and stereo share this wiring some how. For me this was blowing the fuse.
Brianmoore will probably be along to confirm the fuse number as I have got that wrong in the past.
E30325imanc
Post Mon Dec 12, 2011 11:45 am
Yes apparently all the fuses are fine. I did ask to check 11 and 12 though
djsimmy
Post Mon Dec 12, 2011 12:18 pm
i have same issue..
no rev,no mpg, no obc
Rtaylor2208
Post Mon Dec 12, 2011 4:45 pm
Has it had a aftermarket stereo fitted? As I mentioned above mine was due to butchered wiring it could still be related.
E30325imanc
Post Mon Dec 12, 2011 5:57 pm
It has and I'm now wondering if that's the cause as I now remember that everything was working fine before that. Is there anything I can do to check/remedy?
Rtaylor2208
Post Mon Dec 12, 2011 10:42 pm
With mine I bought a new wiring harness adapter (about £5 on ebay) then trimmed all the cut and taped wires and wired into the new harness adapter.
It means then plugging in any stereo from the last 10 years or so in plug and play.
Mine was trully butchered with alot of wires just taped together. If your handy with a soldering iron, solder then heat shrink the joints or buy a tub of male and female bullet connectors (again ebay about £2) and crimp the wires onto them. Make sure all the wire colurs are correct as well. Live to Live etc.
If your not too good with electrics most decent car audio places would do it for you. Shouldn't be expenive It took me about half an hour to sort out and I only know a little about DIY car audio.
E30325imanc
Post Tue Dec 13, 2011 12:28 am
Thanks R. Give me a week,I'm going to try and sort this. Will everyone know if that's what it was :thumb:
TouringTash
Post Tue Dec 13, 2011 2:47 pm
My money would be on the Diff wire being faulty.
Did you ever swap that stock chip for the one I sent you with the 1.3 bits?
318i Touring
E30325imanc
Post Tue Dec 13, 2011 2:54 pm
Hi Tash, no I haven't tried the chip. The guy who installed my stereo is going to look at it tomorrow. If its not that then I'll explore the diff wire next
Cloggy Saint
Post Tue Dec 13, 2011 3:01 pm
TouringTash wrote:My money would be on the Diff wire being faulty.
Pretty sure it's just the speedo' that gets it's reading from the diff?
TouringTash
Post Tue Dec 13, 2011 3:24 pm
I give up with this place.
Jesus H christ :roll.
unsubscribed.
318i Touring
Cloggy Saint
Post Tue Dec 13, 2011 3:48 pm
Problem? :?
E30325imanc
Post Thu Dec 15, 2011 1:07 pm
O.K I don't think it's the head unit. Had it taken out, wiring was done via a block connector and nice and neat. I've been recommended an auto electrician by the guy who installed the stereo, I'll get him to check out the diff wiring?
Post Thu Dec 15, 2011 1:15 pm
Converted from early to late management by any chance?
E30325imanc
Post Thu Dec 15, 2011 1:25 pm
Hi Dan, yes it was. Are we getting any warmer? wink eye What could that effect?
Post Thu Dec 15, 2011 7:04 pm
In that case you have wiring missing from the main body harness. You will have a white 3 pin plug hanging down by the clocks/steering column, this is the input for the RPM/MPG gauge
