Rebuilding a spare cylinder head as a winter project using the zone guide of course!
The head cleaned up well with some £1 Eco save the planet kitchen degreaser (figured this would be gentle against the alloy as it is vegetable based)
Whilst the inlet valves have come up half decent with same degreaser, WD40, and elbow grease, the exhaust valves are piled with burnt on stuff that just aint shifting.
Are there any DIY methods that work? EG leave for a couple of days dipped in XYZ product or thinners or whatever?
Cheers.
How to clean cylinder head valves?
AlpineCab
ross2009
what i done on mine is help the ends in a drill in a vice set the speed going on the drill and use some light wet and dry on the ends etc be carefull not to touch the main stem tho as the tolerences will bugger up for the valve guides
fowler
- Boost Junkie
Dish washer on high temp is also good and a lot less effort but i dont think the missus would be happy.
Or Ross way is also good. i know its crazy but one of the cilit bang does a good job.
EX A-Tech Workshop bitch !!!
gone but not forgotten
AlpineCab
The dishwasher does get used from time to time while she's out shopping.... Couldnt get the cylinder head in though, but no worries cos it came up great anyway.
Was just one whizz round the hot cycle enough for the valves? With powder i presume?
But barry Scott sounds good to me! Which one? theres degreaser, limescale cleaner, toilet gel, foamy stuff, and "with bleach".Didn't use Cillit Bang on the head because its not too good for aluminum, but I guess the valves are a different metal altogether.
Otherwise 'm racking my brains with o level chemistry days - itsnt the black stuff carbon? What about bbq cleaner? time for some tests.
like ths sound of the drill/vice combo too. I'm just a bit concerned about the tolerances all round, and don't want to remove metal. hence the soak it and it just rinses off solution is an attractive concept. But the drill might be the final solution if the dishwasher or bbq cleaner don't work.
HairyScreech
take care with bbq cleaner, some times they can munch aluminium.
it depends how thick the deposits are on the valves, it may not be worth the effort to clean them up unless they are really bad, as the engine will do its best to replace those deposits in short order.
