Central Locking?
Jim320i
E30 Zone News / COTM Team
Post Thu Dec 08, 2011 1:31 pm
Quick question,
Should the Centrol locking on an E30 open from either door or the boot? Mine has only ever worked on the driverside... Boot & Passenger door will not turn :?:
TouringTash
Post Thu Dec 08, 2011 1:54 pm
Yes, well mine does.
had trouble with my sisters polos drivers lock and the central locking so I fitted one of these http://www.rclick.co.uk/product_info.ph ... cts_id=368 the sounder isn't that loud but its the locking we want. Another sounder could be fitted behind the dash winkeye
or as you'll be opening ya wallet Jim how about one of these.
http://www.rclick.co.uk/index.php?cPath=50
As for the locks not turning is it the right key and have you used half a can of WD yet :roll:
318i Touring
Jim320i
Post Thu Dec 08, 2011 2:00 pm
I wouldnt want to fit any after market parts to her, like to keep it all original'ish
When you say the right key, is there a different key for the other doors and boot then?! If so, I dont have it, I have the key to start it that opens the driver door.
Havent tried to kill it in WD yet but i'll give it a whirl. Just odd that neither the boot or passenger door open via a key.
TouringTash
Post Thu Dec 08, 2011 2:09 pm
Jim320i wrote:I wouldnt want to fit any after market parts to her, like to keep it all original'ish.
8O Crumbs bud, that'll be a world of pain and silly money then. Have a butchers at bigwinns for sale advert. OE alarm, just needs a transmitter.
all the locks should be suited to one key (well one set of keys) but loads that I have played with haven't.
318i Touring
Jim320i
Post Thu Dec 08, 2011 2:42 pm
I'm not after an alarm! :mad: Unless your planning on nicking my sorry turd? 8O
TouringTash
Post Thu Dec 08, 2011 2:57 pm
I know, but with all the other projects you have on the go, surely a £40 r click would get it all locking/unlocking via a blip and it would only take 2 hrs to fit. Its surely something you want sorting due to the post?
Sorting out the locks, replacing tumblers will be a good day in this cold weather, loss of a knuckle or two half an inch of skin then maybe add another hour or so for your fingers to regain enough dexterous movement before you pull apart a barrel or two.
Or you could just buy a complete set of second hand locks and keys?
So hardly mad imo but horses for courses bud :wink:
318i Touring
Jim320i
Post Thu Dec 08, 2011 3:24 pm
When you put it like that, it doesnt sound like a bad idea! I have smashed up some finger nails to the point of loosing them too so anything fiddly and cold isnt good at the moment.
I may look into the above when I have some funds... :cool:
Post Thu Dec 08, 2011 3:28 pm
You should definately be able to turn the key in all the locks.
I take it the key that works the drivers door also works the ignition ?
Could have been stolen/attempted stolen in the past and just had the drivers door lock & ignition barrel replaced - meaning you're missing the original key which would work everything else.
Post Thu Dec 08, 2011 3:29 pm
Does the key lock the glovebox ?
TouringTash
Post Thu Dec 08, 2011 4:34 pm
capri_rob wrote:Does the key lock the glovebox ?
beat me too it.
318i Touring
Jim320i
Post Thu Dec 08, 2011 4:39 pm
Ok, had a check again... The passenger side turns slightly but not enough... The boot, nothing happens. The Glove box works fine. So its the same key that starts it that does all this and it also use to open the driver door before I switched the barrel...
TouringTash
Post Thu Dec 08, 2011 4:47 pm
WD FTW.
318i Touring
Post Thu Dec 08, 2011 7:30 pm
E30s were supplied with four keys. One of these is slightly different, and shouldn't work the glovebox or the boot.
Conversely, if the key in question works the boot or glovebox, it should work everywhere, and should work the central locking from the boot and both front doors.
All assuming that no locks have been changed, of course.
I wouldn't consider fitting the rclick actuators, or any other aftermarket tat, to an E30. They are going to be far inferior to the OE stuff.
The OE central locking system is sophisticated, but quite straight forward to trouble shoot and get working properly. Once that's done I can recommend the rclick remote locking kits. I have several in use, and so far have only managed to damage the case of one fob. Spare fobs are available, and easy to code.
TouringTash
Post Thu Dec 08, 2011 7:46 pm
Hmmm
I take it all the actuators are still in place Jim, I know another zoner is having issues but he has neither locks or actuators in place.
If so then £27 +postage will buy the remote keyless entry set up. I wouldn't use the remote locking kit as it contains parts that are going to be far inferior to the OE stuff.
318i Touring
Jim320i
Post Thu Dec 08, 2011 7:59 pm
Hmmm, i'm confused to why my boot doesnt unlock then if it opens the glove box? Its not a major issue, I probably wont tackle it until a much later date. Just wondering what was going on... I've lived with it for 2 years and not really cause me grief!
Post Fri Dec 09, 2011 7:46 am
I've had to replace an E30 boot lock because it was worn ( was a long time ago though ) - the lock and key were both worn and although the key still worked the doors and ignition after a while it wouldnt turn in the boot lock.
Conveniently the bloody thing failed in the locked position and it was on a car with no CL :evil:
A large screwdriver and belt from a hammer soon popped it open :eek:
Got the lock from ECP :wink:
Jim320i
Post Fri Dec 09, 2011 8:35 am
I'll be pestering Matt then :cool: Cheers Rob.
