Pre and post facelift 325i gearboxes and flywheels
Brian28
Are there any differences in pre and post 325i gearbox ratios? They are standard 325i, not sport boxes. And the same for flywheels, any differences? I will be running a pre facelift HC engine on post facelift Motronic management. Thanks.
Grrrmachine
- E30 Zone Wiki / Team Member
boxes are the same, basically you can't use an early starter motor on a late flywheel. The other combos all work.
Brian28
Thanks, useful info on the starter compatibility that will avoid problems further down the line.
Andyboy
- Alpina Colada
Pre facelift flywheels have a trigger for the TDC and speed sensors, a small lug on the edge. Later ones don't.
gooner1
- Out humping Reindeer
So, if swapping to the later 1.3 Motronic Engine management, if the later Starter is
used I will be able to use my later lightened Flywheel, yes
Kedge
Yepgooner1 wrote:So, if swapping to the later 1.3 Motronic Engine management, if the later Starter is
I'm still using the original flywheel (lightened) and started with my 1.3 management.
Kedge
Isn't it just the ratios that are the same? Don't think the later boxes still have the holes in for the 2 flywheel sensor so would be useless on a car with anything other than motronic 1.3 management.Simon13 wrote:boxes are the same, basically you can't use an early starter motor on a late flywheel. The other combos all work.
e301988325i
You're correct, only the early gearbox is compatible with the early 1.1 motronic, but the later gearbox will physically fit and could be used with an upgrade to motronic 1.3Kedge wrote:Isn't it just the ratios that are the same? Don't think the later boxes still have the holes in for the 2 flywheel sensor so would be useless on a car with anything other than motronic 1.3 management.Simon13 wrote:boxes are the same, basically you can't use an early starter motor on a late flywheel. The other combos all work.
I said:
e30topless said:
lock the wife in there
