No power at the fuel pump
Cloggy Saint
Absolutely fine, but a better way is to connect a 12 volt bulb to the fuel pump plug an check that it lights at full brightness.
Cloggy Saint
On the pump relay? I wouldn't do that , if I were you!Cloggy Saint wrote: I'll try connecting pin 30 to earth next.
Try connecting the bulb between 30 and earth.
Cloggy Saint
Cloggy Saint
Where's your battery?
bigwinn
checked the green loop behind the glove box- I had the same issue on Sunday and that was the cause
may not be the same in all cars but some previous alarm/immobiliser works caused me to have no power at the relay or pump
Stu
Stu
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
randomspeedfreak
bigwinn
mine was that the green loop was extended- I thought I made a complete loop but it hadnt worked- I took it back to the simple green loop and it started 1st time
S
S
Cloggy Saint
Normal spot in the engine bay. The car has a factory immobiliser that seems to be in order. I don't get it, last time I used it everything was fine, how can it $hit itself so spectacularly just from being parked?Brianmoooore wrote:Where's your battery?
bigwinn
[quote="Cloggy Saint how can it $hit itself so spectacularly just from being parked?
[/quote]
its an E30...
its an E30...
If your battery's in the front, rather than the boot, then there's only one thing that can stop power getting to pin 30 of the pump relay, and that's a duff connection where the red wire joins the battery + terminal.
Cloggy Saint
The green loop has NOTHING to do with the secondary circuit of the fuel pump feed. It breaks the feed to the + terminal of the ignition coil and the 'power up' terminal of the ECU only.
If your immobiliser affects the fuel pump circuit, it will be connected into the green/purple wire running from the back of the glovebox and along the LH sill.
If the power doesn't get as far as 30 at the relay, then it doesn't stand much chance of getting to the fuse!Cloggy Saint wrote:Would that also apply to no power at fuse 11?
Power at 30 comes directly from the battery.
Cloggy Saint
Sorry, I'm not very clued up on electrics, or anything come to that! I'll check the connection at the battery terminal tomorrow. Probably irrelevant but the car was sitting idle for over a week and in that time the battery drained (it's old) and since charging and refitting it the non-starting issue has occurred.
mrLEE30
The clue is in your last sentence! You have likely disturbed the connection at the battery of the small red wire that goes directly to pin 30. So no power at pin30 means no connection at the battery or a broken wire between battery terminal and pin30- which is a fire risk!
Cloggy Saint
Ok, been back to the car today and it seems there is power at the relay and fuse 11 but still nothing at the fuel pump socket, so is it logical to assume there's a problem between the fuse and the pump? What should I look for next? I was messing around with the speakers in the time between parking up for the last time and it not starting so I guess I could have disturbed something in this area?
An immobiliser, in use or not.Cloggy Saint wrote: What should I look for next?
There is nothing, fitted by BMW, between the outer terminal of fuse 11 and the fuel pump plug, other than a piece of continuous wire, apart from the plug and socket cable tied to the fuel vent pipe at the RH side of the rear seat pan.
The earth point for the pump is the stud at the top of the LH rear wheel arch.
Cloggy Saint
That's where the wire runs, but an immobiliser is most likely to be spliced into it in the glovebox area.Cloggy Saint wrote: am I right in thinking I should be tracing a green/mauve wire along the inside of the left hand sill to the pump?
Cloggy Saint
Factory immobiliser should be spliced in inside the cabin behind the fusebox, but the genuine BMW one only has one circuit, and this should be connected in the green ignition wire.
There were also a few BMW approved immobilisers/alarms available as an option at the time with two circuit immobilisation and one of these circuits could be used for the fuel pump.
You are looking for a green/purple (mauve, if you like) wire which emerges from the duct from the bottom of the fusebox, behind the steering column on LH drive, goes across to behind the top of the speaker panel, down behind the front of the panel, and then back the LH sill.
I've come across one E30 where the splice was actually made inside the fusebox.
Cloggy Saint
Checked the wiring between the fusebox and fuel pump, no sign of a bogus immobiliser or any other damage. So what's the next thing to check? Is there any way the battery draining itself could be contributing to this, it seems like quite a coincidence? I really need this sorting, my car's been standing idle for over a week now
How are you checking for power? It must be done with a bulb of at least 5W. Just using a meter will give false results.
If the bulb lights between fuse 11 and earth (30 - 87 link in place), but not at the fuel pump two pin plug (or the plug and socket at the RH side of the seat pan), there must be a break somewhere in the green/purple wire between the two.
Cloggy Saint
There must be! It's just a single continuous piece of wire, apart from where it goes through the plug and socket on the seat pan.Cloggy Saint wrote: There is definitely no break between the fuse and the pump.
Have you checked inside the fusebox, to see if the wire's unmolested at the outer end of the fuse?
Cloggy Saint
Three screws. One outside the box, one inside the box and obvious, and one under a relay. Don't touch the hex. headed bolt!
The deck has quite a few wires attached to it, so it has to be eased up, but you should find enough slack to get it close to up on edge.
There's one plug pushed onto the circuit board, which may partly pull off, so make sure this is seated properly when you put it back together.
Have you checked for power with the lamp between the green/purple wire at the pump plug, and an independent earth, rather than the brown earth wire in the plug?
Cloggy Saint
Cloggy Saint
No harm in doing that, but you've only got a single piece of wire to check out!
Cloggy Saint
Have you checked at the plug and socket on the seat pan?
