Hi guys, new cars sweet but i have a few bulbs that are out and annoying me so i decided to change them.
All has gone well until putting the dials back in.
does the cluster sit infront of the lower tabs or behind it?
ive currently got it sat behind them but doesnt seem to be sitting right.
Also having problems with the service lights my mate reset them by jumping some pins on the diag port and it cleared it from inspection for around 3 miles.
To which in 10 seconds went to full green, oil change, red, inspection.
any info on a cure for this is appreciated ive read somewhere the battery on the pcb can fail which causes problems.
dial cluster crisis
Sits in front at the bottom, and, yes, you are probably right about the batteries. Get them changed before they leak and destroy the cluster electronics.
