4.10 diff
321gazza
Post Sun Dec 04, 2011 4:30 pm
Can i make my 4.10 diff stronger and fit a lsd and change the ratio or should i just buy a lsd from a 325 sport ect.
gareth
Post Mon Dec 05, 2011 12:12 am
If it's a small case 4.1:1, there's no point spending any money. You'd be better off looking for a medium case 3.91:1 LSD.
It's possible to build a 4.1:1 medium case but finding a donor diff from an early E34 can be trucky and maybe pointless!
what engine / use etc do you have in mind?
321gazza
Post Mon Dec 05, 2011 7:26 am
Hi gareth, the engine is a c20let from a vauxhall (20 ltr turbo) it has 300bhp and trying to sort out a stronger diff and would like a 3.73 or a 3.64 ratio and must have a lsd.
gareth
Post Tue Dec 06, 2011 8:07 pm
In that case, you've got relatively easy pickings. Medium case (188mm) 3.64 and 3.73 LSD's are pretty common, specced on a lot of 325i's over the years. If you're running 300BHP through a 25 year old diff you'll need either a rebuild or a very good one to start with. I can rebuild them and also upgrade locking and number of plates etc if required :)
321gazza
Post Tue Dec 06, 2011 8:52 pm
Hi garerh, just brought a 3.64 lsd diff or i will by saturday so hopefully that will do, i will contact you reguarding refurbing my new diff once its all up and running.
