Uprated Top Mounts
turkeysneck
Post Sat Dec 03, 2011 5:52 pm
I'm after some uprated rear top mounts, I tried the E46 cabriolet ones and they lasted about a fortnight. Can anyone suggest a proper uprated mount and where to get it from. I see there are a couple on ebay but they look pretty similar to what I've tried already.
Green
Post Sat Dec 03, 2011 5:54 pm
They shouldn't have worn that fast, did you use the spacer plate? Also IIRC it's the e46 M3 cab ones that are the favourites.
turkeysneck
Post Sat Dec 03, 2011 5:55 pm
I'm not sure what you mean by the spacer plate, I replaced them exactly as the old ones were removed.
craigieeb
Post Sat Dec 03, 2011 5:57 pm
turkeysneck
Post Sat Dec 03, 2011 7:06 pm
Can anyone explain to me the spacer plate and how it fits.
Grrrmachine
E30 Zone Wiki / Team Member
Post Sat Dec 03, 2011 7:11 pm
The spacer plate is part number 4. Without it, the top of the shock will just punch up and tear the rubber of the top mount within a week.
turkeysneck
Post Sat Dec 03, 2011 7:13 pm
Yea thanks for that I think that's my problem, the next question is where do I get the spacer plate, it's obviously a bit more than just a washer.
BenHar
Post Sat Dec 03, 2011 7:34 pm
turkeysneck
Post Sat Dec 03, 2011 8:31 pm
Thanks for that, I've just fixed them both, hopefully that should do it.
Post Sun Dec 04, 2011 1:05 am
These get missed out because the original Boge dampers have the washer built into the dust cover, where it gets binned along with the old damper.
I really can't see how you expect the top mount to work for long with no washer under it!
