i have no dash or instrument lights when the headlights are turned on in my 318is.
the indicator, parking brake and hi beam light on the instrument cluster still work ok but there is no illumination on the cluster or the rest of the dash.
all fuses are ok.
i think the switch/ dip resistor unit may be faulty, does anyone know which wire is the feed to the dash lights from the switch?
no dash/instrument lights
alan1272
The 'live' instrument light wire is grey/red, and the 'earth' wire is brown/white.
The dimmer resistor is connected between the brown/white and earth, so a quick check of the resistor is to pull out the rear ashtray, and the bulb that illuminates it, and short the brown/white wire to the bulb to earth.
This appears to be a MOT test failure now BTW. Speedo illumination is testable.
alan1272
alan1272
