Red/Black central locking mod - I don't quite get it...
BEERBOY123
Post Sat Dec 03, 2011 10:26 am
I quote from wiki:
Remove battery earth lead. (fine)
Remove the driver's side kick panel/speaker cover.(one screw)
Remove the speaker(three more screws)
Reach into the hole and pull the hank of harness going to the A pillar socket into view(try not to pull the socket out if possible)
I'm fine up to here... then:
Locate and cut the red/black wires,saloons have two,cabbies have three. Q. Cut them where exactly?
Solder and heatshrink the harness ends together,insulate the ends going to the socket. Q. What? I've lost it here. What about the wires I've just cut?
And do I really have to disconnect the battery?
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Post Sat Dec 03, 2011 10:51 am
The red/black wires go to two different pins on the back of the door pillar socket, which you can see the back of through the speaker hole.
Cut through these two or three wires (NOT the red/brown), depending on model, as close to the door socket as possible, abandon the short pieces connected to the socket, then join all the other ends of cut wire you have together.
Personally, I rarely disconnect the battery when working on car electrics (or disconnect power when working on 230 - 400 volt electrics, for that matter), but I like to live dangerously. If you don't disconnect it, you need to be very careful!
BEERBOY123
Post Sat Dec 03, 2011 10:59 am
Thank you, I will have a go later on. With battery disconnected...
So on my iS, cut the two red/black wires, fuse the two cut ends together, shove it all back?
Regards
TouringTash
Post Sat Dec 03, 2011 11:03 am
NEVER, EVER WORK ON 240 LIVE.
318i Touring
BEERBOY123
Post Sat Dec 03, 2011 12:04 pm
OK
I get the principle, and can see the wires going into the square plastic terminal but can't free that from the mounting, how does it come away?
Pleeaase.......
TouringTash
Post Sat Dec 03, 2011 12:48 pm
Been there seen it done it. Boots, gloves, mats, harness, leadx2 and a big guy ready to pull me off if it all goes pear shaped whilst at Liverpool St station connecting up the mains for the 3 phase boards.
With all the HSE involved I only did 2 cables a day and it took a week to do them all. The alternative was shutting of about 30% of the whole station.
Thats when needs must but with 240 just run a bloomin lead or put a torch on ya head if it's 5 amp lighting.
318i Touring
Post Sat Dec 03, 2011 1:44 pm
diable wrote:
TouringTash wrote:NEVER, EVER WORK ON 240 LIVE.
pfft when needs must
3 phase 415V thats another matter......
Still only 230V to earth, and you're hardly likely to touch a different phase with each hand at the same time!
Once in a while I get a belt, but that just serves to sharpen the mind.
Yes, on an iS just join together the two wires. One will be part of a small loom coming along the sill from the back of the car, and the other will be one of two identical wires going to the socket for an interior light delay module.
TouringTash
Post Sat Dec 03, 2011 1:59 pm
Erm anything greater than 60mA with 240Volts AC is enough to cause the old ticker problems.
Edited as it is different with DC.
318i Touring
Post Sat Dec 03, 2011 2:09 pm
TouringTash wrote:Erm anything greater than 60mA with 240Volts AC is enough to cause the old ticker problems.
Been a sparky for over 40 years and still going strong - I think I've built up immunity, as well as a collection of side cutters with large chunks missing from the blades.
TouringTash
Post Sat Dec 03, 2011 3:26 pm
lol you sound like the 6ft8 60 year old brute I used to work with, he used his right thumb nail to check if current was present.
Just gave me a condescending look when I showed him a light stick.
318i Touring
BEERBOY123
Post Sat Dec 03, 2011 3:35 pm
I'm at my wits end here: been on this all day.
How the hell do I get access to the red/black wires? I can see them through the aperture but can't get to them!
Please help before I smash a cup!
BEERBOY123
Post Sat Dec 03, 2011 4:25 pm
I don't think this mod is possible! There's no access!
TouringTash
Post Sat Dec 03, 2011 4:27 pm
Where are you fella?
318i Touring
eko
Old timer
Post Sat Dec 03, 2011 4:35 pm
BEERBOY123 wrote:I don't think this mod is possible! There's no access!
See where the door loom plugs into the A pillar?
Well pull that rubber boot back towaards the door to expose the socket.
Pull the little tabs together on the top and bottom of the socket and pull the socket free.
Then you will see about 4 little tangs(for want of a better word) that secure the socket you want to remove.Just push each `tang` in with your finger and the socket will push through and clear of the A pillar.
You can then pull the plug down through the speaker hole inside the car giving plenty of room and access to chop and join the wires.
Hope that helps.
BEERBOY123
Post Sat Dec 03, 2011 4:40 pm
Thanks all, I'll go and have another look.
Post Sat Dec 03, 2011 4:41 pm
You need to remove the door wiring harness socket (multiplug) from the A-pillar, to gain access.
BEERBOY123
Post Sat Dec 03, 2011 4:47 pm
I don't have any rubber boot under there.
I can see one red/black and then a bundle of wires going into a hard, milky white plastic plug type thing above it, that won't shift for all the tea in China.
eko
Old timer
Post Sat Dec 03, 2011 5:00 pm
BEERBOY123 wrote:I don't have any rubber boot under there..
You have or should have,its on the door side of the A pillar not the inside where you cant see it.
Google pic...
e301988325i
Post Sat Dec 03, 2011 5:03 pm
Open the drivers door fully, there should be a rubber boot covering the wiring between body and car.
Pull back the body side rubber cover, unclip the white socket from the body and then you should have access to the wires!
I said:
e30topless said:
lock the wife in there
BEERBOY123
Post Sat Dec 03, 2011 7:11 pm
I couldn't be more confused.
BEERBOY123
Post Sat Dec 03, 2011 7:19 pm
I can't release the thing from the back of the door.
I might give up on this, my hands are a mess and I'm fed up.
BEERBOY123
Post Sat Dec 03, 2011 7:41 pm
This mod is not possible (for me) to do.
Post Sat Dec 03, 2011 8:02 pm
YOu don't need to unplug the anything of the A pillar to do this mod.
The red/black wire goes through the plug into the door and loops back on itself.
All you need to do is locate the wires, cut them behind the speaker access, and connect/solder them together, thus eliminating the power feed going into the door loop, which causes the plug to corrode at the A pillar.
That's what I did on the cab.
BEERBOY123
Post Sat Dec 03, 2011 8:09 pm
Thanks. There is no corrosion anywhere I've looked or opened. So I might just leave it as a bad job. Thanks all anyway, but I'm too much of a dipstick to follow any of this.
Post Sat Dec 03, 2011 8:13 pm
BEERBOY123
Post Sat Dec 03, 2011 8:30 pm
Thanks, yes I have, but I've given up now, I admit defeat. I'm no Mr Mooooore, these things aren't obvious to me. I tried all day, and am grateful for everyone's help, but I think this should be presented as a difficult and fiddly job, with various theories, and plenty of scope for the layman to go wrong/get confused.
Thanks all the same folks, but I'm going to put everything back as it was tomorrow!
Post Sat Dec 03, 2011 8:32 pm
Where are you located??
This should be an 1hr job at the most tbh.
Post Sat Dec 03, 2011 11:23 pm
As Rav says, there's absolutely no need to disturb the plug and socket in the A pillar. One red/black wire comes along the sill from outside anyway, and the other goes to the probably spare rectangular socket that's floating around behind the speaker.
Plenty of spare wire.
P.S: Those light stick things are good, but aren't 100% reliable. The back of your thumbnail never lies!
Bump
Post Sun Dec 04, 2011 4:16 pm
To be honest having just done this it is pretty straightforward.
To begin with I could only find 1 red and black wire, but there two after a bit more wiggling. In my touring they were just bound up with others in separate strands but you can tell they both headed up into the plug in the A pillar.
Snip them, join them up, battery reconnected and a quick test to make sure it worked, then solder up properly. Good job.
You don't win friends with salad.
TouringTash
Post Sun Dec 04, 2011 4:22 pm
:evil:
@ OP if you are anywhere near Brands Hatch and are partial to a slice of victoria sponge PM me and pop over I'll have it sorted with my brains tied behind my back :thumb:
318i Touring
BEERBOY123
Post Sun Dec 04, 2011 7:45 pm
Thanks bud, sadly nowhere near BH these days, but used to live in Longfield back in the day.
Post Sun Dec 04, 2011 10:02 pm
Brianmoooore wrote: P.S: Those light stick things are good, but aren't 100% reliable. The back of your thumbnail never lies!
I've had a few jolts off the mains myself, but what effect does it have on the back of your thumbnail? winkeye
BEERBOY123
Post Sun Dec 11, 2011 9:31 pm
Folks, thanks for your help, I finally managed to do this today. It didn't really help matters but I'm glad In did it anyway!
Regards
