Just changing my diff oil. The diff is medium case open diff.
In Halfords there is 75w/90 GL5 or EP80w/90 GL5 or EP75w/80 GL4.
Confused which to get??
GL4 or GL5?
tom325sport
tom325sport
Anyone? I'm in the shop.
- Homo Hair
75-90 and 75-80 seem to be recommended BMW diff oils on Opie Oils..
More of them are 75-90.
GL4 and GL5 refer to the amount of anti shear additives in the oil. Diffs. operate under extreme shear, so require a GL5 (Greater amount of additive).
GL4 is specified for the E30 gearbox, because (historically at least) the high level of additives attack 'yellow metals' - the synchronisers.
Modern additives are generally less corrosive to yellow metals, so it may be acceptable to use GL5 for the gearbox as well.
