just read a thread about ht leads,
just wondering ive got a 318i breaker, on the 4th ht lead something was connected around it and this lead goes somewhere underneath the engine,?
is that the cps lead?
on a car im breaking i found one, and on my car it looks like its been removed? whats it for? does it make a difference?
ht leads cps lead has been cut off?
redcar
think its something to do with a pulse sensor so it knows when your engine is sparking and it can work out your mpg economy gauge reading thing.
bmw9818
my car seems to be running fine, econometer is working as well, does it affect mpg?
The missing sensor is nothing to do with the economy gauge or anything like that.
It's a primitive form of a cam position sensor, and tells the engine ECU which of the pair of pistons that are at TDC together is just finishing its exhaust stroke, and which is finishing its compression stroke. With this information it knows which pair of injectors to fire, but with the missing sensor it just fires all the injectors together.
Your engine will work fine without the sensor, but it will work better with it.
bmw9818
ahh i see, so in effect that could cause low mpg? cause i think a po has cut it off for some reason...
The missing signal will probably increase fuel consumption a little, but if it's noticeably poor, then there are almost certainly other reasons.
In most cases where the sensor is missing, it's because aftermarket HT leads have been fitted, as these are often supplied without it.
TouringTash
Isn't the CPS dependent on which management is being employed?
318i Touring
