Strange relay in the boot
wjc
Post Thu Dec 01, 2011 4:20 am
Hi all.
I have come accross a relay / module with ( kick down ) written on it in the boot on a bracket under the aerial / antenna.
I unplugged it and it has not made a change to the way the car drives or the transmission.
Does anyone know what this part operates ?
fowler
Boost Junkie
Post Thu Dec 01, 2011 4:47 am
have you got a switchable auto box in the car ?
EX A-Tech Workshop bitch !!!
gone but not forgotten
mrLEE30
Post Thu Dec 01, 2011 5:05 am
when you say relay do you mean a relay i.e 1 inch by 1 inch with pins, or do you mean the module that is the size of a small book under the arial?
The module is the autobox control unit, and it instructs the autobox when to operate the solenoids that change gear, with it fully unplugged (lareg multipin plug) i would eb very surprised if the box works in anything except limp mode.
If its just a small relay then as its name suggests, it is connected to the switch under the pedal that operates the kick down function for the autobox.
wjc
Post Fri Dec 02, 2011 2:40 am
Thanks guys.
My car is not fitted with a switchable auto trans as far as I know there is no switch on the console. I was told that the previous owner did have a second hand trans fitted before I brought the car. On the transmission plate it has A H in red letters, I can not find any info on this either.
I have not found any reference in my Bentley book to what the module does nor can I find a wiring diagram for it. On the online parts epc the part number only comes up as being for a 530 or 325i.
mrLEE30
Post Sun Dec 04, 2011 7:14 am
ok then next question is what car and what year?
wjc
Post Mon Dec 05, 2011 2:26 am
Sorry it's a 325I, 88 model.
cliff_costa
Post Mon Dec 05, 2011 8:09 am
I have one of les as wel it's more of a moduall. As a gese because it's in the boot I fort it mite be to stop it kicking down if the g fors is to hiy to stop it spinning out round corners but this is just a ges and it wood be nise to now. Then if it is I will be romoving it for sum sideways fun
