Idle Issue when cold!
Adams-Sideways
Wed Nov 30, 2011 10:21 pm
Hi guys, having a little issue with idle at the moment. When i start the car sometimes the idle dives up and down very uniformly from really low nearly stalling back up to 1600rpm? about 10 times (once a second very uniform)
Does the same thing at traffic lights or junctions, all in the first 2-3 minutes of driving. As soon as the car warms up its fine?
What can i test/replace?
Any ideas?
Rtaylor2208
Thu Dec 01, 2011 12:20 pm
Clean out the ICV, this was the same problem another zoner had a few days ago.
1. Disconnect the ICV from the manifold \ Big Rubber Boot
2. Spray carb cleaner in the two openings (assuming you have a T shape) until it stop comming out black
3. Refit
Adams-Sideways
Thu Dec 01, 2011 1:07 pm
Hi mate have you got a picture of where the icv is situated?
Adams-Sideways
Thu Dec 01, 2011 1:08 pm
Oh dont worry, googled it :) Is it worth checking the WOT switch under the throttle body too?
