large case lsd
terrybmw
Post Wed Nov 30, 2011 10:16 am
I have been offered a large case LSD not sure of the ratio yet.my question is at the moment my car has a small diff as it is a 318is.will the large diff fit with my drive shafts or do I have to change anything else
CHR1S1990
Post Wed Nov 30, 2011 10:23 am
What's the LSD off? As a 'true' large case diff won't fit an e30, unless you're talking about the medium case found on 6 pots.
Duke137
Post Wed Nov 30, 2011 10:28 am
All drive shafts are the same apart from the ABS rings which does not affect the diff.
All mounting points are the same you may need to change your prop shaft.
Read this:
http://www.e30zone.net/e30zonewiki/inde ... ferentials
After the table of ratio's the next paragraph answers your questions
Hope that helps
terrybmw
Post Wed Nov 30, 2011 10:29 am
It must be medium one then as it is in a 325 at the minute.I'm waiting for the guy to get back to me at the weekend to find out the ratio.will the medium one fit ?
terrybmw
Post Wed Nov 30, 2011 10:33 am
Just read that link.thanks for that
Duke137
Post Wed Nov 30, 2011 10:37 am
No probs mate, the wiki is pretty good with most of the "usual" questions 8)
