ME AGAIN
greengoblin
Post Wed Nov 23, 2011 9:46 pm
just when i thought it was all fixed its back to its old ways again, hard to start in mornings and left for an hour had a new crank sensor fittd and all was good for an hour then airflow meter was playing up so changed and all was good again ,now takes too long to start and wont go over 45 mph changed blue sensor now 3 times, was trying to do the fort code but when i put ingition on the check light on dash keeps flashing until i press the check buttonit goes out i press throttle 5 times and no light flashes, bought a multimeter to day but not shaw how to use it
Rtaylor2208
Post Wed Nov 23, 2011 10:00 pm
Check these out first.
http://www.e30zone.net/modules.php?name ... c&t=209747
http://www.e30zone.net/modules.php?name ... c&t=209380
Then Check the AFM, and ICV for starters. There should be a guide for the ICV and AFM in the wiki
greengoblin
Post Wed Nov 23, 2011 11:05 pm
does the fuel pump run when ingition is on or when engine is crancked over on a 320i .89 model
rrs
Post Thu Nov 24, 2011 9:15 am
Fuel pump only runs while cranking on any e30 I believe.
rix313
Post Thu Nov 24, 2011 11:41 am
rrs wrote:Fuel pump only runs while cranking on any e30 I believe.
:mad: :mad:
How does the engine continue to run if the pump turns off after starting???
The fuel pump will prime it's self when you tuen the ignition on if the line pressure isn't high enough. It will then run while cranking and the hole time the engine is running until you turn it off.
rrs
Post Thu Nov 24, 2011 12:56 pm
Yes slightly misleading! but as far as I understand it the fuel pump in an e30 does not prime or run until the engine is cranking. Which was what the op was asking.
pressure is held constant in the feed line when the engine is not running and yes the pump runs with the engine.
rix313
Post Thu Nov 24, 2011 5:12 pm
rrs wrote:Yes slightly misleading! but as far as I understand it the fuel pump in an e30 does not prime or run until the engine is cranking. Which was what the op was asking.
:cheers: I get ya now :thumb:
Both of my iS's definantly prime with the ignition is turned on though.
rrs
Post Thu Nov 24, 2011 5:52 pm
Maybe just an m20 trait then.
