As above, I started the car just now after a week.
I found that if the doors are open the windows will work, but if the door is closed they do not.
Also the heater have stopped working full stop.
I have checked the fuses they all seem okay.
On second thoughts the fuse guide i found on the net was for a 318 mine is a 325 should it make a difference?
What would be the reason for the heather and windows problem? Are they linked at all?
heater not working and windows not working if door closed ?
gnrsoul
the window problem sounds like the switch i had this problem and there is a push switch next to the main wire for the doors you can see them when doors are open, try taking the out and giving them a clean up - worked for me.
and is the blower still blowing but no heat??
How about the door mirrors?
bm_guy
Thanks for the reply. I will check the switch tomorrow.gnrsoul wrote:the window problem sounds like the switch i had this problem and there is a push switch next to the main wire for the doors you can see them when doors are open, try taking the out and giving them a clean up - worked for me.
Sorry maybe i was not clear, the blower does not work on either of the 4 settings
bm_guy
Did not check them, will do tomorrow.Brianmoooore wrote:How about the door mirrors?
The interior lights, rear dimister switch, hazard, car lights, stereo all work
bm_guy
Had a quick google search tonight at work. Got a plan for tomorrow:
Bridge the wires 37 and 87 on relays K5 (windows) and K7 (heater) to see if they work.
If they dont replace the relays?
if they do then check for a (green/black?) wire going to the starter?
Failing that is there anything else it can be?
30 and 87.
Highly unlikely there's anything wrong with the relays.
Check the green/black wire. Runs from the fusebox, through the 20 pin engine loom plug and socket near the fusebox, and then to the smallest terminal on the starter motor.
bm_guy
Not that I ever doubted you but spot on again. It was the green and black wire to the starter motor, it had been repaired previously and had come apart. Put a new wire and connector and its all sorted.
Thanks Mr Moooore
Thanks Mr Moooore
