E30 camber/caster correction kits
m_jermyn
Post Wed Nov 23, 2011 12:04 am
So im rebuilding my rear end and have it all apart ready for new bushes, brakes, bearing, brake lines and a nice new shiny coat of paint.
Now whilst I have it out ive been thinking of these camber/castor correction kits to weld in, boy are they expensive considering what they are.
Basically 8 squares or metal with a elongated hole in each of them and 4 longer bolts.
Anyone fitted one of these kits?
Post Wed Nov 23, 2011 7:47 am
Ive done loads, I also sell them :wink:
m_jermyn
Post Wed Nov 23, 2011 7:58 am
How much am I looking at Dan? a˜a
Post Wed Nov 23, 2011 8:06 am
£50 inc recorded post within the UK, usually an extra £5 to send International. This is just for the plates, the bolts/nuts/washers are available from any BMW dealer parts dept, £27 all in with discount last time I bought some which was about 3 or 4 weeks ago. I can send you the bolts too if they work out cheaper to buy here via Cotswold
They are not just longer bolts BTW, they are special made eccentric which gives the adjustment-
m_jermyn
Post Wed Nov 23, 2011 8:20 am
Is that for both camber and toe or just one set Dan?
8 or 4 plates!
Post Wed Nov 23, 2011 8:22 am
8 m8 :)
m_jermyn
Post Wed Nov 23, 2011 10:42 am
Do you know what the part numbers are for the bolts/washes and nuts are?
Oh yeah deal done.
Post Wed Nov 23, 2011 12:03 pm
4 x 33321095102 ECCENTRIC BOLT M12X1,5X98
4 x 33326760668 SELF-LOCKING COLLAR NUT
4 x 33321092310 ECCENTRIC FLAT WASHER
pm me when your ready 8)
rix313
Post Wed Nov 23, 2011 6:23 pm
How much adjustment can be gained from them Dan?
Post Wed Nov 23, 2011 11:34 pm
As much as is needed, ive never measured it TBH, my chromie is dropped about 50mm on the rear and the camber is at just under 1/2 the adjustment and its pretty much back to factory settings, id go more but the arch lip is in the way!
