bit of an odd one this.
any time i start my car it takes between 30sec to a minute before the battery light goes out. i can't even rev the car up to speed up the alternator until the light goes out.
after the light is out, everything is perfect. ticks over fine, revs up and i can drive away with no issues
I've tried 2 other alternators and get the same result.
surely my luck isn't that bad to have 3 faulty ones.
all wiring is new due to having the dta s80pro ecu fitted so thats ruled out.
I've turned the car over in gear a couple of times and when it fires up it seems to do the trick but looking like a fool doing that isn't the best
any help would be great as this is the last thing to sort out, then the car will be finished
thanks in advance
clive
alternator woe's
kingcruizer
"BEFORE I DIE, I WANT TO OWN A CAR WITH AN ENGINE THAT STICKS OUT OF THE BONNET"
kingcruizer
anyone?????
