m52 overheating, fan not kicking in and popping fuses
Green
Post Sun Nov 20, 2011 3:38 am
A strange one today really, everything was working fine this afternoon but after I fitted my exhaust and bled my cooling system the car then sat on the higher end of the temp gauge.
I took it for a drive down the road where it made its way up to red and I pulled over and noticed the fan wasn't on when the ignition was on.
I checked the fuses to see fuse #3 (or 4, it's the fan one either way) had popped. I only had a 25amp spare one rather then a 15 so I put that in there to see if it would work but to no avail.
I waited for it to cool a bit then made my way down the road a bit further and pulled over again, where now the 25amp fuse had also popped :?
The fan loom is one of Danthe's and using the 88deg C thermostat and fan switch... I was wondering if something might have got wet and caused this?
I really need to resolve this later today or I will be pretty buggered without my car this week!
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 9:15 am
Has it got 3 pins on the switch ?, if so its one from a twin speed fan, check the wires are the right way round,check connection of fan wires, and earth wires .
Also make sure the fan isnt seazed
with cars like mine,
Post Sun Nov 20, 2011 11:16 am
Either the fan motor is seizing, or you have chaffed wiring. If it's the former, it needs to be sorted or you are likely to damage the fusebox.
Ideally you need to temporarily replace the fuse with an ammeter, but the current you need to measure maybe above the range of a 'cheap' meter, which generally only go to 10A.
Green
Post Sun Nov 20, 2011 3:40 pm
Wires are correctly fitted, has been running fine for 2 months until last night. Checked the wiring and it all is intact with no bare wires showing.
The fan spins freely when pushed but once again when it reaches temperature it's not cutting in still. I replaced the fuse with another 15a and it's not blown it this time, but like I say it's still not cut in.
I'm also finding it impossible to get heat inside the cabin now, seems like the system is taking forever to bleed.
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 5:45 pm
try parking , front facing up hill, and blead system. make sure heater on full heat.
have you tested the switch ? touch the two wires together to see if it runs fan?
Green
Post Sun Nov 20, 2011 5:50 pm
My driveway it sloped and facing upwards to bleed it. Heaters are on full and still blowing cold.
I wired the fan to the battery which worked on both speeds, i then connected it back to the fan switch and heated it up which made the fan kick in with the ignition on. No blow fuses so far.
I went and put more water in the system (I will fill with coolant again once this has been resolved) and left on idle until it reached temperature but still no fan kicking in when needed. The rad feels cold to the touch and the bottom hose is also cold, although earlier was warm but still no fan action.
Temperature made its way past 3/4s and I switched it off not to overheat. Is this the possible result of a blocked rad or dodgey thermostat?
And still not even a bit of warm air inside!
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 5:57 pm
easiest way to test rad is to take off bottom pipe and a hose in the top, i spose it wouldnt hurt to check thermostat, or just remove it to test if it gets hot without?
Green
Post Sun Nov 20, 2011 6:03 pm
I think I'll give that a crack now, I'm in desperate need of my car tomorrow morning so can't really leave it. I will report back in a bit... of the joys of working in the dark :(
Green
Post Sun Nov 20, 2011 6:15 pm
If it helps diagnose it at all I removed the bottom hose and a bit of water dribbled out but the expansion tank is pretty much full, and now the car is running and still no water is coming out from the bottom :S Steam is coming out from the bottom of the thermostat housing but no water as of yet.
craigieeb
Post Sun Nov 20, 2011 6:52 pm
If your in desperate need of the car and dont have a new thermostat sitting around,
cut out the center of the one you have because it sound's to me like it's fooked!
(you need the outer part of the thermostat, so the thermostat housing can seal)
craigieeb
Post Sun Nov 20, 2011 6:56 pm
the knackered thermostat ties in with my theory (in my head)
the fan is not kicking in because the water is not flowing through the radiator...leading to it not heating the fan switch to allow the fan to kick in ........?
hongkongfuey
Mad-tango-geezer
Post Sun Nov 20, 2011 7:06 pm
craigieeb wrote:the knackered thermostat ties in with my theory (in my head)
i think + 1 to this
on my old one i had a leak on my rad and it only topped up 3/4 so the switch didnt heat up enough to switch the fan
on my m20 the switch is on the thermostat housing
Green
Post Sun Nov 20, 2011 7:25 pm
Back in from the cold with a burnt hand!
I thought I'd try and flush the rad first as it's easier, stuck a hose in the top and it just overflowed so rammed it in the bottom and the contents gushed out. I stuck it back together and filled it back up.
Whilst bleeding the whole rad heated up and then the fan kicked in brilliant!
Further bleeding (about 15 mins after the fan cut back out) the temp rose again and I noticed the fuse had popped again, replaced it when engine was running and it just popped again instantly.
So I turned it off to have dinner and give it another go now, although I've only got one 15a fuse left so going to try my luck with a 10a see how that goes.
So to summarise, fan is now working although fuse has once again blown. Although no incorrect wiring, exposed wires, seized fan...
No bleed screw is also proving bleeding the system a royal pain in the ass.
penton08
Post Sun Nov 20, 2011 7:27 pm
Afaik the cooling fan uses a 30a fuse.
craigieeb
Post Sun Nov 20, 2011 7:34 pm
Green wrote: No bleed screw is also proving bleeding the system a royal pain in the ass.
Hu?
So how are you bleeding the system?
Green
Post Sun Nov 20, 2011 7:42 pm
I've a diagram from somewhere of all the fuses and states that it needs a 15a fuse :S I don't want to use the wrong fuse and have my car go up in flames like using the wrong fuel pump fuse winkeye
With great difficulty craig. Last month when I put new coolant in the head sheered off the bleed screw and I had to think on the spot as I was out in the middle of nowhere so it has now managed to be sealed with silicone sealant I conveniently had on me. I let it heat up and ease off the cap, which explains my burnt hand when it exploded over me.
Post Sun Nov 20, 2011 7:43 pm
penton08 wrote:Afaik the cooling fan uses a 30a fuse.
Full speed is 30A, slow speed is 15A.
Green
Post Sun Nov 20, 2011 8:28 pm
^ That's right.
The 10a blew as soon as the fan kicked in. Switched it for a 15a and turned the car back on and all's working now. Temperature is stable, most of the air is out just need to give it a drive to push the air about.
Will get some sudocrem for my poorly hand as well now that's sorted.
I have about 30 misc fuses in my ash tray now just incase I'm stuck at the side of the road again but will keep an eye on this for the next week.
Green
Post Mon Nov 21, 2011 1:02 am
Just got in, and finally the system appears to be fully bled... 8O
And eventful night to say the least, I also got pulled over for "racing" my friend who was following me closely to make sure my car didn't blow up or anything :roll:
Everything seems to be in order, fan working properly now... although what the hell caused it to pop so many fuses? :?
