ok iv got an obc in the touring that i bought off here a while back, fitted it following the wiki and it was fine for about 6 months, at which point it just stopped reading from the dash.
it comes on with the ignition, all the lights and buttons work, it keeps time perfectly and the stalk switch cycles through the functions.
but it seems that its not receiving the info from the dash, it dosent read speed or mpg at all, they just stay on zero.
now i have checked the loom, flashed it for continuity to all pins and it seems to check out ok, with out the loom plugged into the dash it dosent even turn on so its getting its power from the yellow plug on the dash.
im a bit stumped as there seems to be no logical reason for it to suddenly stop reading.
is there a reset function on the obc?
OBC not receiving signal
HairyScreech
mb15
If you disconnect the battery this resets the obc time and date so i would think it would reset the other functions as well.
HairyScreech
hmm, well i did that a couple of days ago to change the regulator pack on the alternator.
so we can count that one helping out as the battery was off for about 20 mins.
- **BANNED**
Is your SI board functioning correctly?
A lot of instument related faults seem to stem from this area,and the OBC does take it's information/signals from the cluster....
Youth is wasted on the young.
Something I usually advise against, but the only way you're going to find where the problem is here, is by trying a fresh OBC, followed by a fresh cluster.
HairyScreech
Damn. Well I think I have another set of clocks for a six pot back at home so I'll have a look for them and try those first.
As for the Si board I'm not sure if it works properly as much to my discredit I haven't bothered resetting it since I have had the car. I'll also give that a shot
