Also where does the OBC get these readings from and how accurate are they.
Thanks (in advance)
OBC calculates how much fuel is being used by measuring the width of and counting the injector pulses. Accuracy depends on how close to spec. your injectors are.leeparkes wrote: Also where does the OBC get these readings from and how accurate are they.![]()
No, because these injectors are delivering more fuel that the OBC expects, so it will think the car is using less fuel than it actually is.Rav335uk wrote:Surely, if this is reading pulse from the injectors, it should work correctly with any engine in then??
