Drivers door lock problem.
ah
My drivers door lock,locks the car fine.But when I unlock it,it makes a rattly noise and its not a smooth action, This is the second E30 I've owned that does this,whats causing it?
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
- **BANNED**
Driver's door lock gets lot's of use,so wear is inevitable.
In essence,all the lock barrel does is to dis-connect the external handle from the latch.
What I do now is remove both the latch and lock barrel,clean and lubricate the latch so that it works smoothly and freely.This bit is free!
Then buy a 'Lock Repair Kit' from your local friendly for about £20.This gives you a bag of bits to build up a new lock barrel to suit your key.With both of these jobs done,you should have a driver's door lock that will work properly and last another twenty years...
Youth is wasted on the young.
