help
damian666
i have a 1990 e30 325i motosport. it was running then it just cut out and it wont start up again. it is sparking, it is getting fuel to the injector rail but the spark plugs are bone dry. ANY IDEAS as i have ran out? Thanks
Pull out the white DME relay (under cover near the air filter), and use wire links to connect pin 30 to both 87s of its socket. If this doesn't help and you are sure that fuel is under pressure in the fuel rail, then check out the condition of the wires under the lower rubber cover of the C192 plug and socket, under the middle of the inlet manifold, where the injector loom plugs into the body loom.
