weird head light problem
jimbob29
Post Tue Nov 15, 2011 11:17 am
took car to garage to replace the offside headlights and now when i turn on normall beam the main beams come on at same time but with the same brightness as normall beam and when i switch to high beam the main beams get brighter as normal i quite like all 4 lights working on normall beam as well as high beam working as normal :D any ideas what he could of done?
Billwill
Post Tue Nov 15, 2011 11:30 am
I dont exactly understand your description. Each light housing has a single element H1 bulb installed (at least mine does!). On Low beam...the outer two bulbs light up. When you activate High beam....the outer two bulbs stay on but are now joined by the two inner bulbs.
So I do not understand how you can expect to have all four light assemblies ON when on Low beam....you can only get this when on High beam. :?
