I'm getting bored with my fuel tank
Since I had it replaced by a new one I've had the following issues.
1. Sometimes the car will act as if it has run out of fuel when approaching half empty (from full). This hasn't happened recently but the only time I ran it down as far as the fuel light was with multiple short journeys.
2. The car is incredibly slow to fill. I can usually only fill 22 litres before the pump times out. The fuel backs up the filler neck and cuts the pump off if I run the pump at anything more than minimum rate.
I did think I had fuel gauge issues when the car stopped on half way but after careful checking of how much fuel has been put in, used and the range achieved I think that it is reasonably accurate.
I'm guessing this has to be a breather issue of some sort - Where should I be checking and can I do this with the tank in place? The other worry I have is that I may have blocked something up when I treated the tank with POR-15 before it was fitted so if that scenario fits the symptoms I'd be interested to hear about it!
Thanks...
Morat
