Occasional starting issue
chewy320
Post Sun Nov 13, 2011 6:31 am
Just wondering if anyone can help with this. My car drives fine but every now and again refuses to start. I turn the key and nothing what so ever happens, it doesn't turn over or make any attempt to start. If I leave it for a while and try again it will start just fine.
Is this something to do with the ignition or starter motor? Is something just on it's way out?
Any help much appreciated. Thanks!
Post Sun Nov 13, 2011 8:40 am
Lots of things it could be unfortunately :cry:
Something as simple as a bad engine to body earth
Faulty ignition switch
Sticking starter motor
Start by removing the earth straps and cleaning the connections - I had a golf GTi which had exactly the same fault - turned out to be a crappy earth connection - 2 mins with some wet and dry paper and it never did it again :wink:
jimf
Post Sun Nov 13, 2011 9:55 am
I had this recently and it turned out to be the wire under the dash from the ignition to the terminal block had come loose, check your yellow/black wire is secure under steering column.
Post Sun Nov 13, 2011 10:10 am
The best way to create an unreliable car, beset with intermittent faults is to dive in trying this and that with no basis in logic.
Before you disturb anything, remove the cover from the diagnostic socket at the top front of the engine, and sure you know where pins 11 and 14 are, and find a short piece of wire suitable for joining these two pins together.
The next time the fault occurs, make sure the car is out of gear, use the piece of wire to short the two pins together, and see if this makes the starter operate or not.
chewy320
Post Tue Nov 15, 2011 5:50 pm
Thanks guys!
