Hi all
I want to get some side skirts for my 318is. I want to keep it looking as standard as possible but get rid of the horrible black under belly thats visible without them Which ones should I be looking for and how much should I pay!?
Any help much appreciated!
E30 side skirts
The only ones which look OK without fitting the rest of the kit are the "SE" skirts commonly found on SE spec facelift cars and Tourings.
Shouldnt be massively expensive - maybe £30 - £50 for a decent pair - you will need to drill your sills in order to fit the plugs for the clips to go into though which does put people off.
All the clips are still available new from the dealers.
jonny323i
there is a set in the for sale section for £39
Touring for life
I hadnt looked - not a bad guess on the pricejonny323i wrote:there is a set in the for sale section for £39
Grrrmachine
- E30 Zone Wiki / Team Member
In development, but the Wiki does have a file on SE skirts:
http://www.e30zone.net/e30zonewiki/inde ... ide_Skirts
hongkongfuey
- Mad-tango-geezer
You could tiger seal on the clips instead of drilling
with cars like mine,
Jozi
I was just going to say the same thing. Something I would be much happier doing than drilling holes and hopefully something that will keep my iX skirts stuck to the car for a long time.hongkongfuey wrote:You could tiger seal on the clips instead of drilling
If you're going to do a job, do it properly!hongkongfuey wrote:You could tiger seal on the clips instead of drilling
Drilling the holes in the sill does not promote rust.
