Maybe a silly question... I have a 1989 325 touring and the exhaust pipes are angled from the back box, ideally I would like standard oem part.
Had a chat with my local dealer and they checked their system and said pipes are angled instead of straight from the back box - is this correct?
If there is an oem part with straight pipes would anyone have the part number?
Thanks in advance
325 Touring Exhaust - straight or angled / best alternative
Imax
BMW 325i Touring
Braided hoses and slowly restoring back to its former glory...
tom325sport
I think most Tourings and pre-facelift 325i's had angled pipes - well mine did.
Can you get them cut off and have some straight one's put on if your exhaust is all good?
sweep
Heres one i have
http://www.ebay.co.uk/itm/280767244915? ... 1555.l2649
Imax
Looks like I will struggle with an oem part with straight pipes - what would be the best after market alternative?
Ideally I want pipes to be straight, and sound good but not to obvious. Looked at scorpion back section which is around 300 from eurocarparts. Are there any alternatives worth considering?
The pipes have to be angled or kinked in order to properly fit into the valance cutout.
If you're going aftermarket and want straight pipes you need to make sure that the straight pipes are offset to the left of the rear box - if they come out in the middle they won't clear the valance :
I wanted to use my stainless exhaust from my old pre-facelift E30, but because the tailpipes came out of the rear box in the centre it wouldnt fit
