Hi guys, put my 320i through its mot yesterday and it fail on emissons.
The hc was spot on but the co was 3.94 and should have been 3.5,
Can anyone on here think of a reason for the richness?
Ive read on the wiki it could be the blue temp sensor? Is there an thing else that could be causing the problem?
Any info would really help cheers
rich running
TheMeathead
Grrrmachine
- E30 Zone Wiki / Team Member
A weepy injector or six might also show up, but I'd expect that to also yield high HC readings, as would old/worn ignition components (dizzy/rotor/spark plugs).
TheMeathead
Thats what i thought, the dizzy is in gd conditionas is are the leads.
The sparks are brand new ngk's.
How would i check the injectors without having to send then away?
Slightly rich sends the CO up much quicker than HC. It needs to be seriously rich to bump up HC by large amounts.
How many miles on your injectors?
You can get some indication of a leaky injector by monitoring fuel pressure when the engine is off, with the fuel pipes both clamped off and unclamped.
TheMeathead
The injectors are the original ones as far as i can tell, the cars covered 97k
ill give that a try tomz.
In that case, they are overdue for a rebuild!TheMeathead wrote:The injectors are the original ones as far as i can tell, the cars covered 97k
