This engine is a good one and has been built to a very high standard. Its done about 4000 miles since built, but the problem has only occured since the maf was fitted. It was done by Ant at A-tech and i have tried endlessly to get hold of him, but no luck! I think hes done a good job and he seems to know his stuff!?!
Right the issue is an intermitent loss of power followed by it kicking back in and reving through the problem. this happens around 6000 rpm, not so much in 2nd gear but regularly in 3rd and 4th but not every time!
It is very violent when this happens and no good on a wet road!!!
I thought it might be a mapping issue but have had it remapped by wayne at chip wizzards, (top man!!!) he thought it might be an electicle problem but not sure?
intermitent fault on m20 b28 with maf! help please...
e301988325i
I think you need to take your car to circuit motors at castle combe Nr Bristol if you live anywhere close!
I said:
e30topless said:
lock the wife in there
sammydickie
I live in poole, dorset so combs not far. These guys good? What do they do and how do you think they might be able to help? Thanks for the info.
e301988325i
Map cars tuning etc, good with E30's, Paul owns an E30 M3, 'shepsEvo3' on here.
They're your best bet of a fix, not many people can help you with a MAF conversion involved.
I said:
sammydickie
do you have a contact number for them? if not ill google. Thanks
e301988325i
01249 782 596
Ant's no longer doing this stuff. . .
I said:
