Hi folks, now I have the car running it is time to move on to the next issue.
When the indicators are selected they flash at double speed as they would if a bulb was out. I have checked all the bulbs and they are fine.
I have changed the stalk and what I 'think' is the relay which came attached to it.
Is there a separate relay somewhere else?
Indicators flashing at double speed but all bulbs are fine!
Billwill
The relay for the flashers should have three contacts with a Brown wire, two Green/yellow wires and a Green/violet wire attached. This is according to my circuit diagram...I have not personaly worked in this area before. It does seem to be fed by the hazard light pushbutton but I am not sure if that is involved.
Are you sure you have the correct wattage bulbs installed and the grounding points are good?
jimf
Thanks bill, it was the wrong wattage bulbs as you suggested.
I would like to thanks the previous owner of TCF 94S for that
HairyScreech
mechanical flashers rely on the resistance of the bulbs to produce there flash rate, as the resistance of the bulbs dictates how long it takes to charge the coil and fire the relay, if you have a bulb out or the wrong wattage bulbs you will get an odd flash rate.
this is why electronic relays were invented to allow one design of relay to be used across the board.
It's required by law that indicator 'relays' give an indication of failed or wrong wattage indicator bulbs, and this is usually achieved by changing the flashing speed outside of the legal range.HairyScreech wrote:mechanical flashers rely on the resistance of the bulbs to produce there flash rate, as the resistance of the bulbs dictates how long it takes to charge the coil and fire the relay, if you have a bulb out or the wrong wattage bulbs you will get an odd flash rate.
If you have additional (trailer) indicator bulbs, then you are required to have a separate indication of failure of these, which is the double arrow light in the row of warning lights at the bottom of the cluster.
zv1530
Mine work fine, the Left hand inds. and the warning hazards - but nothing on the Right side, front or back. In the Right flash switch position the relay clicks at double speed as if a bulb were out. I've replaced the bulbs and checked/found a good earth at the rear light cluster. Now it's head-scratching time. Any advice appreciated
DHFiS
switch fault?zv1530 wrote:Mine work fine, the Left hand inds. and the warning hazards - but nothing on the Right side, front or back. In the Right flash switch position the relay clicks at double speed as if a bulb were out. I've replaced the bulbs and checked/found a good earth at the rear light cluster. Now it's head-scratching time. Any advice appreciated
http://www.e30zone.net/modules.php?name ... =indicator
