Ive got rear motors, door looms and switchs but the car only has one white block to fit one switch in by the gear stick not two.
Is that for something else or am i missing another white block?
retrofit rear leccy windows.
Sanchez
eko
- Old timer
The other White block will be there somewhere mate,likely tucked under the carpet.
Plus another one for the isolator switch.eko wrote:The other White block will be there somewhere mate,likely tucked under the carpet.
Sanchez
Hope so.eko wrote:The other White block will be there somewhere mate,likely tucked under the carpet.
I dont have the small square switch, do i need both that one and the rectangle one?Brianmoooore wrote:Plus another one for the isolator switch.eko wrote:The other White block will be there somewhere mate,likely tucked under the carpet.
With the square switch disconnected, the rear windows will onl work from the switches on the centre console. The switches in the rear door cards will do nothing.
If you join the wires together that go to the switch, both the console switches and the door card switches will work the windows.
Sanchez
Looks like ill need one then, I have a 11month old girl!!!
