Tarox G88 Brake Disc Query
DoctorDrift
Post Mon Oct 31, 2011 9:31 pm
Hello Guys,
Think i might have messed up and bought the wrong brake discs for my 318is....
I bought some Tarox G88 discs from Demon Tweeks a couple of weeks ago, they are 260mm x 12mm solid not vented. Should i have vented discs like the standard ones or can i use these? According to Demon Tweeks these are the correct fitment for the 318is but im not convinced as the ones on the car are vented.
Any help is greatly appreciated
mrb27
Post Mon Oct 31, 2011 9:36 pm
you will need vented discs m8, the new ones wont fit a vented disc caliper
DoctorDrift
Post Mon Oct 31, 2011 9:40 pm
Dam! Bloody Demon Tweeks!
Ok so am i right in thinking i need the 260mm x 22mm Vented discs then?
Sanchez
Post Mon Oct 31, 2011 9:54 pm
E36 318is has solid discs, are they 4 stud ones or 5?
Sanchez
Post Mon Oct 31, 2011 9:56 pm
You need to watch DT cause they also will tell you Cabby shocks are different than saloon and touring shockers.
DoctorDrift
Post Mon Oct 31, 2011 10:00 pm
Yes they are 4 stud, its an e30 though?
Sanchez
Post Mon Oct 31, 2011 10:04 pm
Just tell tweeks the ones that are advertised dont fit, get them to change them.
DoctorDrift
Post Mon Oct 31, 2011 10:15 pm
yep, guess i dont have any choice really :evil:
Thanks for your advice guys
e301988325i
Post Tue Nov 01, 2011 9:55 am
You can safely order 325i discs for a 318iS, it's the boggo 318i that uses solid discs.
I said:
e30topless said:
lock the wife in there
