i changed over the blue and brown sensors, cant really tell much of a difference tbh, changed over the idle valve as well, thats sitting nicely now..
however i drove it around for about 30min the heat is coming out perfectly very hot, however the temp is bang on 1/4 cold, i stopped for about 10mins, flicked ignition on temp goes straight to the middle, start it up it goes back down to the quarter slowly..
ive got a 323i radiator i stuck on over a year back when i did the hgasket, im thinking that its got to be that, either that or a stuck thermostat thats opening too early or not closing up?
will it pick up anything in diagnostics...
basically im getting 17-20 mpg! the donor car was getting about 30 easily through town 35-40 on a motorway...
checked the spark plugs, they seem fine, normal browny colour, engine revs freely, and pulls pretty well..
pipe above do anything? its been taped up coming off the inlet manifold, just under the throttle body...
