TIA
Anyone recommend a good Solar Trickle charger??
- E30 Zone Meets/Events Team
As above lads, cabs been put away into a garage for the winter, and need a solar charger as there is no live feed into the garage.
TIA
TIA
Come on guys, someone must use one.
Gwynleym10
By far the best ones are the VW part ones. They actually use them to keep their new car batteries topped up while in transit.
They have the best type of solar and they have all the right diodes so your battery doesn't go flat.
Can't find any on UK but here is what the look like. http://www.ebay.co.uk/itm/VOLKSWAGEN-SO ... 19c80ebbbc
Don't bother with cheap crap.
Couldn't you just take the battery out of the car though?
PeteE30Tourer
I bought this one from Maplin for £20. Probably comes under the "cheap crap" category, but I thought it was worth a punt. Haven't tried it yet so cant validate that it's any good.
http://www.maplin.co.uk/solar-powered-1 ... rger-98358
Back behind an M20, but now I can hear it better.
Taking the battery out isn't an option, I would like to leave it connected so the alarm is on.
Gwynleym10
Maplin Solar stuff is usually OK. At least the soldering should be OK unlike a lot on ebay.
The Maplin Panel is 1.5w and the VW is 3.2w. I also think the VW one works better in lower light conditions.
You could always buy a nice Romag 12v solar panel have some lights and charge your neighbours batteries as well!
Gwynleym10
The you need to make sure the solar panel is powerful enough to charge more than the alarm will drain.
e301988325i
Mine's the same as this, works a treat albeit wth the car garaged it doesn't really get used. When I have used it it does keep the battery topped up perfectly.
I said:
e30topless said:
lock the wife in there
PeteE30Tourer
Just picked up a second one from Maplin this evening - 2.4W for £12.99 a half price at the moment.
http://mobile.maplin.co.uk/module.aspx?moduleno=223251
Got one each for the cab and one for the VW campervan - both seldom used in the winter.
I've ordered the one in my link above, should do the job at 4watts.
