my e30 is 325 auto and i am thinking of doing an auto to manual converion
so i have an eye on a 320 manual box are the ratios much different on a 325 manual
what about diff ratios with the auto at 70mph on the cars clocks the engines doing 2800rpm do we think the 320 box will mess up the ratios are the gear box out puts the same ratio before the diff?
320-325 gearbox differances
parkin10
325 box (260) is stronger than the 320 (240) box, but the 240 shouldn't give problems with a standard engine. Both will need their matching prop. shaft, which are longer than your existing auto. one.
Fourth and fifth gear ratios are the same for both boxes, so this will have no bearing on diff. choice.
Third gear on the 240 box is roughly half way between the 260 'Sports' option gearbox and the standard 360 one.
Second gear on the 240 is similar to the 'Sports' 260 one, although first gear on a 240 is much closer to the standard 260 than the 'sports' version.
- **BANNED**
I have used a 240 'box with my 2.7 for about 5 years with no problems.
For a 325i,a 3.73 or 3.91 diff would be my choice.
Youth is wasted on the young.
Barx325i
parkin10
thank for your replys
so what diff ratio do i happen to have now
i only ask because i think that it feels a little over geared with the auto in
never quite in the right gear at the right time
mrb27
i also have the 240 box on my 2.7 with a 4.10 diff!!! it goes like fook off the mark but forget motorway driving... expect 5mpg with my setup lol
if i had my way i would go with the 3.73 as above, best of both worlds.. i have a 3.64 lsd in need of rebuild but kinda puttin it off as i lobe the 'around town' feel of the 4.10
parkin10
well it gone tits up
some one beat me to the donor car
just going to have to stick my foot on the gas and be patient a bit longer
hongkongfuey
- Mad-tango-geezer
325 box
1st gear 3.83
2nd 2.20
3rd 1.40
4th 1.00
5th 0.81
rev 3.46
diff either 3.64/3.73/3.9
320 box
1st gear 3.72
2nd 2.02
3rd 1.32
4th 1.00
5th 0.81
rev 3.45
got these of wikipedia
i have a 325 with a 3.73 diff
also have a 325 gearbx for sale if you need one
1st gear 3.83
2nd 2.20
3rd 1.40
4th 1.00
5th 0.81
rev 3.46
320 box
1st gear 3.72
2nd 2.02
3rd 1.32
4th 1.00
5th 0.81
rev 3.45
with cars like mine,
