Stalling when cold - carb model
greg124
Post Sat Oct 22, 2011 2:35 pm
Since the weather turned cold last week, our lass has complained that her chromie is difficult to start, and stalls when she gets to the end of the road - not good when you're pulling out onto a dual carriageway.
This is an M10 engine with Pierberg 2BE carb. As it runs great when it is warm, I'm guessing it could be one of the temperature sensors.
On fuel injected models we know about the blue temperature sensor - which screws into the block, so presumably measures water temperature.
There is a blue sensor on this engine, but it's screwed into the rear-most branch of the inlet manifold - air temperature?
There are 2 further sensors in the casting off the front passenger side of the head, that the radiator hoses fit onto. One of these has a single electrical connection with two brown/white wires connected to it. The other is yellow and connected to two vacuum hoses.
Any advise on which of these (if any) could be causing the problem, and how to test them, would be much appreciated,
Schadenfreude - the German's haven't got a word for that.
greg124
Post Sun Oct 23, 2011 2:03 pm
Right. After much trawling on the web, I found a site which had a document on how to fault-find the Pierberg carb.
Translating it from German, I have been able to test the temperature sensors, and they are working as per specification.
So, I decided to whip the air cleaner off to get a better look at the carb. On removing the air cleaner cover, I noticed that the choke solenoid linkage had popped off. Clipped it back on. The car started straight away. Took it to the end of the road, and it didn't stall. However, it was fairly warm by 11.00 this morning, so we'll see what happens on the next cold morning.
