Another heater matrix "how to remove*
craigieeb
Post Fri Oct 21, 2011 6:01 pm
I'v got a leak from the matrix,
it was dripping from the front join, so i'v taken off the top pipe (see pics below)
checked the "o" ring and there is nothing wrong with it,
so i started taking off the side of the matrix,
but how the hell do I get t the last screw...???
the one on the bottom near the bulk head,
there seems to be a brake assembly in the way
:-x
This is the only job on an E30 i'v never done :roll:
bmw9818
Post Fri Oct 21, 2011 6:45 pm
the one in the bottom centre....? ratchet with a crosshead tip possibly..
craigieeb
Post Fri Oct 21, 2011 6:46 pm
There's not enough of a gap to get anything in
James90
Post Fri Oct 21, 2011 6:57 pm
dremel tool and grind the face off it?
craigieeb
Post Fri Oct 21, 2011 7:01 pm
Butchery I can do that,
but...........
it has to go back together again
Post Fri Oct 21, 2011 7:09 pm
have you not got one of those screwdrivers where you can insert different bits in the end? If so, can you not use one of the bits but turn it with a 10mm ring spanner?
craigieeb
Post Fri Oct 21, 2011 7:16 pm
Yeah could do,
didnt think of that, before i ran out of light, got p1ssed off with it,
and threw a screwdriver at it
lol
calmed down now tho
penton08
Post Fri Oct 21, 2011 9:44 pm
Remove the brake pivot plate. It will make removing the matrix easier too winkeye
craigieeb
Post Fri Oct 21, 2011 11:57 pm
does the whole matrix need to come out just to take off the plastic end plate?
Post Sat Oct 22, 2011 12:01 am
that screw is damn near impossible to get off,
what I do is carefully break off the tab on the old valve to get it out, then remove the torx bolt with pliers once the valve is out of the way.. then refit the new valve and use a small 8mm bolt, it works fine and I did it to my own car 8 years ago, it's still doing it's job :D
Post Sat Oct 22, 2011 12:07 am
[Edit] just noticed you need the matrix out craig ? i thought it was the valve you were replacing :?
I have never done this not while the dash was in place ..
craigieeb
Post Sat Oct 22, 2011 12:59 am
thats just it tho, does the whole matrix need to come out just to take the plastic end cap off?
or does it just come off when the screws are out........
I think the plastic pipe might be cracked
eko
Old timer
Post Sat Oct 22, 2011 1:17 am
craigieeb wrote:thats just it tho, does the whole matrix need to come out just to take the plastic end cap off?
Whole matrix out from memory mate.
As Penton said,remove that pivot plate,makes life much easier!
craigieeb
Post Sat Oct 22, 2011 1:19 am
bugga
