washer jets
djscottfree
hi all my washer jets for my windscreen have stopped working, is there a fuse for these ?? my mot is due next month so i need these to work, where should i be looking !! cheers
- threelander
maybe just blocked mate try cleaning them out with a fine needle
djscottfree
no cant hear the motor running
- Brianmoooore
Fuse is the same one as for the wipers.
Washer circuit is extremely simple - First ignition switch position puts 12 volts live on the purple/black to the pump, and the washer switch earths the brown/black when you pull it.
Do the wipers start up shortly after you pull the washer switch?
Pull the plug off of the pump and connect a 12 volt bulb in place of the pump. Does it light when you pull the washer switch with the ignition switch in position 1?
djscottfree
the wipers work but the washer motor doesn't it easy to change the motor many thanks
djscottfree
hi all i can't see the washer pump anyone tell me where this is located please, cheers
- Brianmoooore
Hopefully you'll find it pushed into the washer bottle through a rubber grommet! If you can't, that probably explains why it doesn't work.
