The left hand side of the main cluster/ clocks speedo etc has stopped lighting up.
Could it just be a bulb at the back of cluster thats out ?
If so how hard is this to change - my diy skills are at most a 4 out of 10 , so can i try this, or will someone need to take it out and look at it in garage ?
1989 325i sport
Lights out on speedo cluster
- **BANNED**
Perhaps a 2 out of 10....
Remove the cluster and swap the bulb.
http://www.e30zone.net/e30zonewiki/inde ... eplacement
Youth is wasted on the young.
si911t
Thanks for that . To me that looks like a 8 out of 10 job !daimlerman wrote:Perhaps a 2 out of 10....
I will have a go see what happens, just worried about not putting it back together tight and ending up with annoying rattling noises.
One more thing if you dont mind, what kind of bulb will i need ?
Thanks again
- **BANNED**
Do not be tempted to fit a bigger bulb,because the extra heat will melt the orange mask....
Easy as peas - the wiki guide is spot on - all you need is a couple of decent screwdrivers.
May as well replace both bulbs whilst you have the clocks out - can't remember the wattage off the top of my head but any motor factor will stock them and you'll get them even cheaper off ebay or suchlike.
Edit : just seen malc's post
http://www.ebay.co.uk/itm/504-CAPLESS-C ... 415d8972d2
si911t
Thank you again
