Hi All,
Needed some technical advice from those who know about wheel spacing and upgraded brakes.
I bought a set of 6 pot Wilwood calipers, but to install them have needed to space out the front wheels by 15mm...
Hardly practical, as the front wheels stick out way too much, but also they lock up when pushed hard despite the ABS having been fitted and apparently operational.
Could anyone give me any ideas on how to correct/mitigate the effects of a 15mm spacer out front (maybe spacing out the rear, or offset wheels), and also any indication as to why the wheels would lock up even with ABS working?
Thanks in advance,
adil
Wilwood 6 pot calipers
ross2009
drop a pm to keri-wms hes the brake expert on here he might be able to help
keri-WMS
We're talking by PM but there's not much advice I can offer to be honest! If the wheels can't fit round the caliper things need to move, different offset wheels are nicer than spacers - but the effect on handling is the same. Wider track at the rear won't fix any steering issues at the front, it'll just be visual.
The ABS shouldn't be stopped working by a change of caliper though, unless it's got big change in piston area...but even then it's unlikely.
I'd be checking the ABS sensors etc - start swapping OEM bits to see if they are all ok.
Jozi
I asked on here ages ago how to test ABS sensors, this might be of some help: http://www.e30zone.net/modules.php?name ... &p=2217465
adil325i
Thanks all,
Am thinking to do away with it all - just doesnt fit the purpose at the moment.
I will be checking the ABS system, but the spacers have ruined the drive of the car.
Any other suggestions will be greatly appreciated at this point.
All the Best,
adil
All the Best,
adil
BadDave
Adil
Can you tell me which Willwoods you have,and the part numbers please.
Also ndis details inc diameter/thickness and how thick the mounting bell is(where it mates with the E30 hub)
I'll see how the dimensions compare with my GN111's(with 335x32mm disks) and might be able to help once i've done the maths.
My 7" wide wheels have a 40mm offset and require a 30mm spacer
adil325i
Hi Dave,
Ill find out and get back to you - where would the part numbers be? I still have all the original packaging, so can potentially get this from it.
Getting the dimensions of the bell may take some more time, but will get this also.
Thank you - your touring project looks interesting!
All the Best,
adil
All the Best,
adil
BadDave
Adil,
Part number(s) for the calipers are normally on the caliper itself and also on the individual boxes in which it/they came
Caliper part number should be 7 digits IIRC
Alternatively,can you identify your caliper from the following link?
http://www.wilwood.com/Calipers/CaliperListLanding.aspx
Once I've got the caliper details,I'll look up the tech specs pdf and compare it to mine
adil325i
Hi BadDave,
Have been trying to get the part numbers, but just saw the link you'd left!
Mine are the Billet Superlite 6R Radial Mount Calipers listed.
All the Best,
adil
All the Best,
adil
BadDave
Adil,
Are the disk's you are using 20.6mm or the 32mm thick
How thick is the mounting bell(where it meets the hub) and what is the disk offset(distance from the inside of the mounting bell to the inner disk face)?
HairyScreech
a really massive increase in power could well be overwhelming the abs's ability to reduce line pressure at the front.
BadDave
My 6 pot Wilwood setup works fine with the ABS(E30 M3 master cylinder).
It kicks in when needed.The only time it's locked up was when there was a problematic ABS sensor.Once changed for a known working one the system worked as intended.
HairyScreech
hmm, so it wont be that then.
