Fuel pipe replacement
blackrs2000custom
Post Mon Oct 17, 2011 6:13 pm
Hi, new to bmws but not doing car repairs.
The fuel pipe that runs along the sill need replacing, is it a drop the tank job ? and is it the return pipe or feed ? (its not the one grouped together with the brake pipe)
Thanks Neil
Post Mon Oct 17, 2011 6:59 pm
Thats the breather pipe. The flow and returns run side by side with the brake pipe.
andy523
Post Mon Oct 17, 2011 10:19 pm
i went to my local motor factors and they supplied me with a 8mm white hard plastic pipe which you heat up and bend to suit. Perfect for the vent pipe
blackrs2000custom
Post Mon Oct 17, 2011 10:50 pm
Cheers,
does the tank need dropped to replace it ?
Post Tue Oct 18, 2011 12:00 am
You can remove it completely, and revert to a similar arrangement as used on pre facelift cars.
Post Tue Oct 18, 2011 7:32 am
Or buy the correct pre-shaped perfect fitting pipe from BMW for under £20 which will last another 20+ Years ( more if you waxoyl it regularly ) and won't look like a bodge :D
You don't need to drop the tank.
Are you sure the fuel pipes are OK ?
If the vent pipe is knackered it stands a good chance the fuel pipes will be past their best too.
All still available from BMW :wink:
