vibration/grinding
Cloggy Saint
- **BANNED**
Steering rack secure?
Youth is wasted on the young.
Cloggy Saint
mrb27
i just changed my power steering pump due to horrible vibrations when i turn the wheel, all sorted now
if it is the pump you will get the vibration when not moving and moving.. if it only vibrates in motion i would look at bearings/g.box etc, ofc your wheels are balanced ok..
Tom_Maverick
topmounts!! you get a proper shimmy when they are knacked and it'd explain the grinding.. get a mate to turn the wheel and you feel the top of the mount and have a listen.. I did exactly that and the left one was grinding away like a teen mum at a strip club..
Cloggy Saint
Ajsingh
Have u checked the rear diff? Green, another zoner, had his diff replaced and it worked its way loose! Caused by a few bolts coming out and it was causing all sorts of vibrations
Its 99% probably not that, but hey
E30 Crazy!
Cloggy Saint
