I've got a secondhand diff here I was going to fit this morning. I bought it about a year ago, I can't remember who from now.
Before getting too far into the job, I drained the oil out as it's easier to fill the unit off the car.
What's come out is pink, like ATF/power steering oil. I've never seen pink EP75/90, so I'm thinking it's game over for my replacement diff, and I've been mugged-over again.
Is there such a thing as pink EP oil? If not, there's no way this diff is going on my car - I can't be arsed to put it in and have to take it straight out again.
BTW, it's an open diff, not a slipper.
TIA
Stuart.
Pink Diff Oil????
StuBeeDoo
Redline diff. oil is pink, IIRC.
How viscous is the oil? ATF is much thinner than any EP gear oil when cold.
StuBeeDoo
hazd31
Did a diff swap the other day and my mate said atf oil was the stuff to put in, I fortunatly still had a bit of the correct gear oil in the workshop.
I think its a common trick, Thinner if its being changed daily on a race car?
StuBeeDoo
I've been out and compared the two. What came out is definitely quite a bit thinner than brand new EP75/90.StuBeeDoo wrote:It didn't seem as thick as the new stuff I bought to go in Brian.
hazd31 wrote:I think its a common trick
Speaking of common tricks; I'm so p155ed off with replacing diffs in my E30 that I'll probably end-up bunging a handful of sawdust in the one that's on the car at the moment.
