Clutch pedal
brettski
Hi guys my clutch pedal is very loose at the top of its travel and is higher than the brake pedal. It doesnt wobble from side to side and it works fine when pressed any idea what the problem could be? Thanks.
Probably that the brake pedal is too low. Can you lift the brake pedal from its rest position?
brettski
I'll check it Brian but the clutch is really loose. You can press it down with you finger and it just pops back up!
brettski
Right the brake pedal is the same height as the accelerator. The clutch feels loose but has resistance at the same height as the brake pedal. Any ideas?
The complete clutch linkage is very simple, and all readily visible, if you remove the under dash panel on the driver's side. It's just a bell crank on a shaft, connected directly to the master hydraulic cylinder.
Any problems here should be easy to see, but short of a fastener working loose, it's difficult to think of anything that could be wrong.
If the clutch pedal can be pushed down a considerable distance, without actually doing anything at the clutch end, then there's probably air in the hydraulic system, probably indicating a failing master cylinder.
brettski
Brilliant thanks for that Brian!
