Sports gearbox question
E30_Crazy
Post Fri Oct 14, 2011 3:03 am
Reading in my Haynes manual, it says that for some "high performance" manual gearboxes, to use ATF in them, and to contact a BMW technician for servicing. Well, the "technician" I spoke to said that they just follow what's on the sticker on the side of the box, and if that fails just stick some SAE 80 or GL-4/GL-5 in it. I have a Getrag 260 sport box, and was wondering if this fell under the "high performance" category, or if it just uses manual SAE 80 like the rest.
Feeling around inside the servicing hole, my little finger did come out a kind of greyish color, so this steered me away from the usually reddish ATF. I filled it up with SAE 80/GL-5, but it's only done enough to go up on and back off the ramp at the DIY workshop, incase this is a mistake.
Basically, the long story of me just trying to find out what oil to use in a 260 sport box. Anyone?
gooner1
Out humping Reindeer
Post Fri Oct 14, 2011 6:49 am
**BANNED**
Post Fri Oct 14, 2011 10:31 am
My wife drives my E30's every now and then,but when she drove them on a regular basis she moaned that the 'gears were heavy'....her regular trip was less than a mile...I pointed out that the 'box needed time to warm through but she still moaned.
Hence me using ATF in my 'boxes instead of gearoil,it's thinner,therefore the change is lighter from cold.I would expect a worn 'box to be noisier when warm,though.
Youth is wasted on the young.
Post Fri Oct 14, 2011 1:30 pm
You can use ATF in any E30 gearbox without problems, and, as said above, it will give an easier gear change when cold, but won't help with any noise problems.
You must not, however, use EP mineral oil in a gearbox designed to be used on ATF. The reason is that any bronze used in the construction will be attacked by the EP additives.
Andyboy
Alpina Colada
Post Fri Oct 14, 2011 5:27 pm
Brianmoooore wrote: You must not, however, use EP mineral oil in a gearbox designed to be used on ATF. The reason is that any bronze used in the construction will be attacked by the EP additives.
You will also find it virtually impossible to change gear when cold.
E30_Crazy
Post Fri Oct 14, 2011 6:06 pm
Ok, thanks for the info.
Another thing, I notice that the sound is a little louder when the box is out of gear and I let up on the clutch (compared to my last sport box). It's almost a sort of whine. Could that just be from a modified engine (don't see why though...) or is it on it's last few miles?
ross2009
Post Fri Oct 14, 2011 7:08 pm
no thats the thrust bearing we should have changed that really while it was out
Turbo M20
v8 project 6.0 twin turbo
