water help
e30121
MY e30 cabs keeps getting water in it when it rains behind drivers side seat in rear checked all seals cant see any leaks any info guys cheers
kolee
your roof has a leak.
Jim320i
- E30 Zone News / COTM Team
Did you fit the roof or pay someone else to? If someone else, I would take it back...
If it was you, you may have to alter the position to create a proper seal all the way round, although it does sound like a perished rubber somewhere thats letting it in. Is there no evidence of damp on the inside of the roof once it raining?
BenHar
Probably the drain holes from the space the roof folds into are blocked.
They are very tricky to see.
Search the forum for pictures.
Ben
Ben
BenHar
Not necessarily going to be a cab. specific leak. Rusted out/ loose rear floor pan drain plugs are a common cause of this. They are about 3" in diameter, and have three lugs on them that locate them as they are twisted into place.
BenHar
True. Blocked drains I'm talking about show water under the rear seat before it gets to the foot well.Brianmoooore wrote:Not necessarily going to be a cab. specific leak.
Ben
