Pedal Removal??
J_A_C_K_Y_D
Post Sun Oct 09, 2011 9:44 pm
Hi Guys,
I've started stripping down the e30 in preperation to rebuild it, managed to drop all the suspension, strip most of the running gear but i'm stuck on something really trivial.... how do I get the floor mounted pedal off?
Thanks in advance
Elliot
Post Sun Oct 09, 2011 10:11 pm
It should unclip - there are plastic lugs at the rear of the pedal which you need to press in to release it - fiddly though and easy to break.
New pedals still available if you bust it though I think
Post Sun Oct 09, 2011 11:08 pm
Disconnect it at the top end first, then do as above, pushing the pedal sideways at the same time, so that it comes out one side at a time.
The pedal is actually intended to be disposable by BMW, but nine times out of ten they come out OK.
J_A_C_K_Y_D
Post Sun Oct 09, 2011 11:33 pm
Ah thats great
A massive help, thanks both
