Currently have an E30 M3 which I am going to fit aircon
As I couldnt find a E30 M3 aircon unit I went out and bought a 316 with air con fitted - was a fully working unit.
Now for the problem
The m3 does not have the wiring for the air con unit so do I removed the full interior loom from the 316 and put this in the M3 or carefully remove the sections I need and wire it into the m3 loom.
The M3 is currently having an S50 engine fitted so will the 316 loom be fine to wire into the S50 loom?
wiring for Air con unit
I have a complete M3 factory aircon set up in a car that I will probably be removing. The A/C can be seen working and is ice cold. I will NOT split the kit.
bmwe30mtech
I'm not certain what wiring you think the M3 is missing. ALL E30's have the wiring needed to plug the air-con heater box into, because it is identical to the standard heater box plug (only difference is between pre and post facelift).
So your air-box from the 316i will plug into your M3 loom with no problem, assuming they are both facelift looms.
The other air-con loom is in the engine bay, and plugs into the fuse box.
I personally just missed out on a full M3 setup on ebay, went for £40!
bmwe30mtech wrote:I'm not certain what wiring you think the M3 is missing. ALL E30's have the wiring needed to plug the air-con heater box into, because it is identical to the standard heater box plug (only difference is between pre and post facelift).
As you well know Paul, the difference between a pile of 25 year old butchered ebay
scrap and cold A/C is about £1500
bmwe30mtech
Very true Pete, condensor £95, radiator £200, front panel £150, painting panel £150, R134a conversion £140, o rings £20, mounting parts £50, gas charge £50, for a start, plus labour for most people...
£40 was still a steal though, I was only after the heater valve too! Did you manage to find a spare one Pete?
You as well! Got talking to someone, and missed the end of the auction by ten minutes.bmwe30mtech wrote: I personally just missed out on a full M3 setup on ebay, went for £40!
On facelift E30s, at least, there are a couple of unused wires running from the fusebox to the heater box plug in non aircon cars, which are used when aircon is fitted.
